What does "maintain the voltage" mean?Make sure the battery is pre-charged to at least 12v and don't boost it if it's weak - the charging system is meant to only maintain the voltage.
That's a good idea, get a full charge on it and if it discharges back to the barely starting level again, and let's assume it's a good battery since the people at the auto parts store charged it assuring you that the battery is healthy, then we are in the battery is not receiving enough charge zone. Check all the wires and connections, trace all the paths and confirm it's correctly wired according to the manufacturer specs. After that I would use a multimeter to check the voltage being supplied from the charging coils (remember this is AC from coils) to the rectifier (converts to DC) and the voltage delivery to the battery at idle/in gear (12.5 - 14 VDC typically - you want to see something in the 13+ volts to maintain charge on a "12 V battery" more like 12.5 with a full charge). Also, since it's an electric start make sure the solenoid is the correct size/type (magneto?) What's the input/output say for that in the specs? Remember wire placement can be critical..too close to the flywheel can induce fluctuations in sensitive components.What does "maintain the voltage" mean?
What voltage value should it maintain?
If a battery will barely crank and start a motor (but does) should that battery be immediately removed so it can be pre-charged?
