I've been working for a couple years on a 1966 or so SabreCraft, with an identical vintage Mercruiser package including the GM inline 6. It's been nothing but a PITA, but I'm too dumb to quit.
I got the boat in early '22, tuned it up, got it running, put maybe 10 hours on the engine (during which I had a lot of fun). Not surprisingly, it still had some hiccups. Both ignition and fuel mixing were problematic and after it died on the water twice I put it away for the season. Winter of '23 I upgraded to a knock-off HEI system, rebuilt the carb and as part of addressing fuel system problems I found and installed period appropriate mechanical water pump, and replaced all the fuel line from the water/fuel separator/filter to the carb. What I did not do was drain and replace the fuel as part of either my winterizing or de-winterizing tasks.
After all this work, the engin ran as well as a 50-year old pickup truck engine can run. For about another two hours. And when it died on me again, and after I diagnosed that fuel was not getting through the fuel pump and to the carb (even after I replaced the fuel pump with another new fuel pump), I put the boat away again. It's spring, and hope springs eternal right? I'd still like to get her on the water.
I just had this thought and kind of smackd my own forehead. I replaced the fuel filter/separator in '22, ran the hboat ten hours or so, parked. The fuel sat in the tank, with a generous serving of Sta-bil fuel additive ove rthe winter of '22-23. I got at most another hour or two of use, and then lost fuel. Could the filter clog up in that short amount of use where I (like an idiot, I know) left several gallons of fuel in the tank over the winter? I can't remember preciselyh, but on this occasion I think I was forced by circumstances to use an ethanol-added fuel, which I usually avoid. So, is it a stretch to think 12 hours of use (at the most) could clog the filter and that all I need is a clean filter?
I mean, I'll find out soon enough, as the replacement filter will be delivered tomorrow. But curious what this august group thinks.
