Blue Skies
I recently purchased a boat that came with a nice dinghy with a 2007 40 HP four stroke Honda outboard. During the purchase process, the broker and I took the dinghy out and it performed well. I believe the tell tale was pissing out the side of the engine. WE finished up and the broker said he would lift the dink back up after I had gone. I suspect that he may not have flushed the engine. The boat sat from the end of December until last week while we went thru the purchase and repair process.
I took the dinghy down last week and it started right up, but no water from the tell tale. I assumed that the impeller was probably shot so I loaded it on a trailer and brought it home. I rebuilt the entire water pump with an OEM kit and reinstalled the lower end on the motor. I was super disappointed to see that I still had no flow at the tell tale. I pulled the discharge hose and the fitting going into the block, everything seems clear, but I'm getting no water at all. I even tried running a weed wacker cord down thru the fitting but encountered no obstructions. I then removed the water jacket cover. It appeared to be clear, but it looks like someone had added some gasket maker to the o-ring/gasket. I then turned the water on to the ear muffs again and started the engine. I believe that I should be seeing water flow in this jacket cover, but once again I had no water at all.
At this point, I'm stumped. I'm thinking of pulling the lower end again, putting it into a tray of water and spinning the shaft with a battery drill to prove that the pump is working. I don't have a manual yet so I don't know where else to look. Any of you Honda experts have any sage advice for me?
Thanks , in advance.
Blue Skies,
Dave
Blue Skies,
Dave
