04 Evinrude 175HP difficulty removing timing cover.
I suspect the optical sensor is none functioning would like to remove an replace.
I’ve broke the top bolt loose holding the timing cover which seams to be jammed on.
Squirted a little wd40 on a few hours ago an it’s still jammed on.
Any suggestions on removing the cover it’s real flimsy an I certainly don’t want to break it. Thanks for advice.
