1978 Mercury 800 2 stroke dies under a load
Cmas56
I have a 1978 mercury 80hp 2 stroke motor ive been trying to get going but cant seem to get past this final issue. For reference, this boat and motor sat up for roughly 13 years. I pull the boat out and had go redo almost every wire in the boat for batteries, trim, and whatever else coming from the plug on the side of the motor. I cleaned the fuel tank out with new gas and allowed it to dry for a few hours. I replaced all fuel lines from the tank to the carbs. Fully rebuilt both carbs and fuel pump (which i ended up by passing with an electric fuel pump later). I also replaced spark plugs, switch box, rectifier, stator, and trigger twice. I took the boat to a mercury mechanic to check timing, compression, and ensure all cylinders were firing and that all checked good. We also adjusted the mixture screws on the carbs 1.5 turns out.
The main issue: motor runs fine when hooked up to a water hose but once you put it in the lake, you can give it about half throttle, maybe 2,000rpm, and it runs fine. Try to give it full throttle and it bogs down and dies instantly. The reason i changed to an electric fuel pump was because there was clearly a fuel delivery issue before as it wouldnt even hardly idle unless i kept pumping the bulb at the fuel tank, even after rebuilding the fuel pump. Since ive bypassed the fuel pump on the block, i noticed there is no suction coming from that fuel pump. Also, there is usually a puddle of fuel sitting in front of the carbs when you pull that front cover off. Im thinking there is a lack of crankcase pressure but not sure. Any and all input would be greatly appreciated.
Well-----If there is no crankcase COMPRESSION to drive the fuel pump , you may need to tear this motor apart.-----To start post the actual cylinder compression values ( today ) as that may offer clues on the condition of your motor.-----Did you replace the water pump impeller?----One of the most important pieces on an outboard like yours !
Yes water pump was completely rebuilt. I do not have the exact compression values, as i said, a mechanic done that and i dont remember what values he read. I can check them myself but not sure when i can check them. So is the cylinder compression what drives that fuel pump on the block?
No it is not cylinder compression.-----It is CRANKCASE compression pressure that drives the pump.-----If you have crankcase compression issues the motor will not run properly.----Then again you may just need to open low speed mixture srews to prevent bogging.----Adjust them 1/8th turn at a time.
Ok yea, i tried adjusting that little by little out on the lake and it still bogs down and dies when given full throttle
You set maximum timing advance.----Idle timing looks after itself.----Timing on these is not the same as a 350 chevy.-----Do not start adjusting / guessing.
But that's what I noticing,was with the timing light, it's about 3° or so more advanced than the research I found , of 0 to 3°. It's running around 5 to 6° faster.
I understand idle timing. To set while it's in the water with a back pressure of the exhaust. I'm just wondering with it bogging out during High throttle if it's a fuel diaphragm? I noticed that if I throttle back and throttle faster quickly I will get the full potential of the motor. But if I just slowly start to throttle up it bogs out. Hence why I was thinking combination of two things the timing being too advanced slightly. And or a fuel of diaphragm. Which I'm trying to research on how to check or replace.
Any input I would gladly love to hear about!
Open low speed mixture screws 1/8th turn at a time and teat run.-----Idle timing is the time that throttle plates open.----Actual idle timing does not matter.
