ok bought a used Blue Fin with a 35 merc.
runs good but only has netural and reverse also the two arms that lock the motot in the down position will not release from the small horizontal shaft that controls the height of tilt. this is not a power tilt/trim
I have heard that engine must be in forward before the arms will release.
could this just be a case of improper cabel adjustment. or is my lower unit junk. Reverse works fine .
But I need to replace the water impeller.HELP
