" Jim... I assume you're c
" Jim... I assume you're checking the spark with the s/plugs out to allow the highest rpm available. If not, do so.
Disconnect the RED main electrical plug, then crank the engine via the starter solenoid (solenoid battery cable term to solenoid 3/8" nut). If you now have proper spark (jumps a 7/16" gap), replace the ignition switch.
If still no spark, check the stator under the flywheel. If it's cracked and oozing a sticky substance from it, that would prevent the stator from providing the proper voltage to the powerpack(s). The cure would be to replace the stator.
It's always possible that a powerpack could fail, but the above are the most likely causes.
Joe (30+ Years With OMC) "
