This no spark issue is driving me crazy. I have followed the workshop manual with no luck.
It cranks but no spark either at distributor or directly at coil.
I bypassed the neutral safety switch and the engine is in neutral.
The following parts are new:
Coil, ignition regulator, distributor, distributor cap, rotor.
With ignition on I do not get voltage at the pink wire going in to coil. This connector I replaced as original was loose.
40 amp fuse in circuit is fine.
Wire to tach is connected properly.
Battery fully charged and voltmeter shows excellent voltage.
Any ideas?
Any ideas?
