IMO, Chrysler Marine designed their R W cooling system quite differently from the others (back then) and from what you will see today.
Just a suggestion....... you may want to update the way in which the seawater path is plumbed.
For one thing..... I would rid myself of any belt driven seawater pump.
Some of the Chrysler guys here have gone with the Johnson crankshaft pump. An adapter is required, and you can find what the guys did in this forum section.
Secondly.... even while the array of T-stat housings look different, most will direct the seawater in a similar fashion.
As obatsea says above..... "
Seawater to raw water pump. Raw water pump to thermostat housing intake. Thermostat housing to circulating pump (usually a large u shaped hose) circulating pump directly to block. Swish swish swish around inside engine. Back to thermostat housing. Thermostat housing to exhaust manifolds. Over the side."
What some may not understand, is the bi-pass side of the system.
While the full supply of seawater is going to the T-stat housing, only a portion of it goes through the engine on as "As Needed/As Required" basis. The actual thermostat dictates engine seawater demands.
Depending on engine demands (heat dissipation to seawater), most seawater is going on to the exhaust system.
Again..... just a suggestion:
