Fish Stix
Hi guys - a long while ago I did head work on my 1980-era 318's, and put the cross-over restrictor plates in only one of the installs. Now, in the hot weather, the engine without the restrictor plates has been acting up hen hot, so I figured it's time to put new gaskets with the restrictor plates in - making it match the other engine (which is the same age and works perfectly). perfect timing now that summer is going to an end.
The felpro gasket set is the same as the other engine, and all appears correct, except as in the images, the very top part of the head's center port is visible and is open. It seems that my head isn't tall enough to cover to top of that center port, but it also doesn't matter because the gasket wouldn't seal it either.
So I'm looking to you guys as to what to do next - do I have the wrong intake and gasket set for this head? Can I block off the gap area with some metal, somehow, or does it simply not matter.
Thanks as always
Fish Stix III
Thanks as always
Fish Stix III
