Purchased a Glastron CSS 19 with a 1989 454 with water in the oil. Drained the oil, rebuilt the carb, flushed the fuel tank. Idled with muffs on the lower unit. Temp gage went to 3/4 then dropped to a bit over 1/4, when t stat opened dirty nasty water came from exhaust pipes. Oil has water in it again.onitores oil before tstat opened and level was fine. After tstat opened water in the oil. What should I check first? Manifolds? Then oil cooler? Then heads and block? 1st post here, have rebuild many motors, just been 25 years since owning my old Bayliner 2651. Thanks for the help in advance!
