"I Have a CARVER 28 with 2 VOL
"I Have a CARVER 28 with 2 VOLVO PENTA DIESEL AD31 model 1993 (I think)
Last Summer one engine was getting hot during operation without loss of coolant or any other apparent problem. My mechanic suggested gasket problem. He opened the engine. The gasket was OK but he found a hidden hole in the coolant system which he repaired.
Engine now is not getting hot but I run into another bigger problem:
When I run the boat BOTH engines do not go more than 2000 rev each and the speed stays at 15 Km per hour.
I did this test:
With both engines on I get 15 Km/Hour maximum
When I turn off right engine speed falls to 12 Km/hour.
When I turn off left engine speed falls again to 12 Km/hour.
In the fuel filters we found some dirty substances and it was thought the fuel system should be checked and cleaned.
Pumps and were taken out and cleaned tested by professional, turbo system was checked and cleaned. Exhaust system was checked and cleaned. Air filters were removed temporarily.
The problem is not solved. Both engines start and run OK until I reach 2000 revs, then they appear to lose momentum and the boat cannot plane. They have about 600 hours of operation each which means to me they cannot be too old.
Now, at a certain moment when the pump engineer was making some adjustments on board while testing, the engines started going faster and reached about 3000 revs. He told me he had actually increased the fuel supply via a special valve(?) on the pumps.
This worked for about one hour and the boat was cruising at about 40 Km/hour (no smoke). Then slowly it lost power again and went back to 2000 revs (15 Km/h). Please note that at this level(2000 revs) it can go long trips without any additional problems.
The latest test was to bypass the engine fuel system and supply clean fuel from an external tank directly to the pump filters to both engines. Still it did not work but by opening the filters we found that they were not full of fuel which according to my mechanic is an indication that we still have not enough fuel supply.
What makes me puzzled is how can both engines suffer from the same problem?
If we suppose that the problem is related to the overheating of last summer and the change of the gasket then it would be located to this engine only.
Unless if:
Is it possible that one engine has the problem and both show the same revs count during operation?
If the problem was with one engine only is it possible that each one separately produces the same speed (12 Km/hour)?
We have checked props and hull, they are clean. No smoke, no noise, no vibrations.
My opinion is that if the problem was with the compression or the props or the hull or the transmission then it should not go at 40 km/hour for an hour and and then drop again. Am I correct?
I am located in a small city South Greece and all local ‘experts’ seem to run out of ideas.
Does any body have any suggestions??"
I did this test:
Unless if:
