On the 1970 60hp the pee hole is under the water when operating.It makes it imposible to see if the water is circulating while in the water.The newer johnsons have the tell tale water outlet on the lower moter cowling.I really dont like depending on the overheat light on the controll box.So this is what I did. There is a small threaded plug on the top of the head 03075443- plug,cylinder.I took out the plug and the thread size matched the copper fittings I had .With a 90 degree elbow threaded into the hole I then plumed 1/4 in od copper tubeing useing compretion fittings.I drilled a 3/8 hole in the lower cowling with a rubber gromet .And plumed the 1/4 in copper tube through it .I now have a visible pee hole when I get it on the water.The one qustion I have on this is will it affect my thermostat opperating correctlly.It pisses a nice steady stream and most important it is visible when out on the water.Thanks Tony.
