Jeff, all due respect to you here. I just want to add a bit of clarity to this.
Aquamatic Propellers - Fitting a Long Hub Propeller to A Short Hub Shaft
I can tell you for certain (technically speaking and with 24+ years experience), that unless you are comparing them side/by/side prior to being installed in the lower unit gear case, this Long/Short prop shaft business is a misnomer.
With the correct and necessary spacer/line cutter installed, there is no such thing as a short or long AQ series s/p drive propeller shaft,
I say this because we cannot install either length propeller hub without the correct spacer/line cutter for the prop shaft.
Once the correct spacer/line cutter has been installed, the net amount of exposed propeller shaft and splines is equal between the different drive models.
Now and ONLY now can we install the propeller and spinner.
( 250, 270, 275 = the short spacer/line cutter.... whereas the 280, 285 290 = the long spacer/line cutter..... and with no exceptions. )
I go through Aquamatic props regularly. We like to explore remote areas that are often quite shallow. My 250 outdrive takes the short hub propeller – the one where the bendy tab locks the cone.
Yes, all 250 lower units must use the short hub propeller.
Or..... in order to use a long hub propeller, you could install a 275 lower unit, and you will have the internal threads necessary for the spinner and center keeper bolt.
The place that I’d been getting the short hub props no longer handles them. I bought a long hub prop – the one that uses a bolt into the end of the cone to lock it, just to see if I could make it work. I couldn’t come up with a solution. That long hub propeller needs a threaded shaft and mine isn’t threaded.
I believe that you meant to say "Internally" threaded shaft for the center keeper bolt!
In my image below, I show an X dimension.
When the correct spacer/line cutter is installed (as it must be), this X dimension is the same between the 250/270/275 and the 280/285/290 propeller shafts.
