BF225 - Tips for removing propshaft holder?
brettmarl
Trying to dig into my lower unit to replace drive shaft bearing. Gear shaft already removed and it’s in fwd gear per the removal procedure.
Procedure on 17-19 says to remove the two big bolts then pry the propshaft unit out with screwdriver using the two opposing slots.
I’ve broken the tip on two huge screwdrivers. Not moving. Tried to rotate / break free by hitting on ears but nothing. Tried heat and PB blaster and not budging.
Any tips for getting this out?
Honda 225 video on YT makes it look super trivial pry and wiggle like stated in the manual.
I’ve been some Yamaha examples where they attach slide hammer to threaded propshaft but that seems like it would be a bad idea and put a lot of force on bearing stack.
At my wits end.
