haveing issues on 1970 60 hp electric shift. After replacing seals i hooked the lower end back up, now it is stuck in foward any time i run it in nutral my prop turns. if i shut off and put it in revers i get revers and any time i put in in foward i get foward. first guess was that the cylinodes wernt working so i put in a old set that i knew worked, and tryed that but i had the same out come. i know power to both green and blue wires puts it in revers and when i put it in fowared i dont have any power, and nutral i have power to green which i know is correct, so power wise im good, i have cheacked with test light with someone at controles shifting between gears. as i was replaceing the seals i had the lower unit up side down,sideways, and every other way, could this of knocked anything out of place? i never opened the gear case i just replace the seals under the water pump and a new baring in the houseing. so in all my problem is that the prop is turing in nutral and my bases are covered up to the silinoids. what pass that could be causeing the prop to turn?
