Evinrude 6 HP gear shift clutch alienment
Goldentouch
How to engage/compress the propeller shaft spring activated clutch/og to engage with the F/N/R gear yoke for selecting which gear is engage with the Pinion gear. When removing the full propeller shaft/gear assembly, the shifter yoke at the base of the engins gear ffoot assemble is observed moving left/right, but the propeller shaft does not connect to the F/N/R shift Rod going to the engine head. Is there a setup or techique to installing the propeller gear shaft/spring activated clutch dog in the lower unit? Gear F/N/R rod does not move casuing the clutch/dog to compress to move gears between F/N/R.
