Dave Bowman
Hi, am new to this forum and hope some one can help.
My stb engine over heats and the coolant ends up in the bilge. I figure I had a bad hose or something so,topped up the tank and started the engine to look for a leak. After about 5 minutes of running at 1000 rpm the coolant started coming out the tank overflow. I swapped the cap with the one from the port engine and the same think happened but it took awhile longer. I can replace both caps but it does not seem logical that they would both be bad. The port engine does not over heat. Can anything else cause this?
