I too have a 1979 36' Grand Banks with twin Lehmans, engine water pump impeller maybe slipping on the shaft at higher RPMs. May need to change engine water pump. Have seen this several times on cats and cummins engines!"I have a 1979 Grand Banks 36 with twin Ford Lehman 120's, 6 cyl. The port engine is overheating by 20 to 30 degrees. I have done extensive work to try to find out the problem and at am the end of my rope for a solution.
Here is a summary of the work done - all 3 raw water heat exchangers have been taken off, inspected and back flushed. Then these were exchanged with the starboard engine and still the port engine overheats. The riser has been replaced - the old one didn't show very much accumulation. Engine temperature gauge reads the same at main steering station and bridge station. Also, it has been connected to starboard engine and shows normal temperature. The temperature gauge sensor has been exchanged with the starboard one and there is no change.
The thermostat was replaced but no improvement. The new one has also been exchanged with the one in the starboard engine and no change.
The raw water impeller pump has been rebuilt. The raw water intake has been exchanged with the starboard engine one. No change - the problem persists. Raw water exhaust on port engine looks about the same as the starboard.
The port engine sounds like it is running well - sounds the same as starboard engine. No noticeable leakage of oil or coolant.
We have run sea trials at 1200 rpm and 1560 rpm (chosen arbitrarily). At the lower rpm, temperature is good. At higher rpm, the reading goes to 210 F.
I need to get this problem solved as soon as possible. Any suggestions would be greatly appreciated.
Jeff Neville [email protected]"
I see this is an older thread but contains a lot of useful info. I have a current temperature problem with my SP90 (single engine in a Nauticat)... gently grounded on a sandbar last week (Bahamas) and eventually floated off on the tide. The next day noted that the T gauge - usually at 185/190 F was just over 200. Sailed back to marina and have done all the below but still see 205 or so at idle (before I shut down) within 15 minutes of starting.
Cleaned strainer (a wee bit of sand and 3 blades of grass)
Replaced impeller (old one looked perfect)
Removed water hose at exhaust elbow and felt around for obstructions with finger -- negative)
Opened primary heat exchanger ends for inspection - a bit scaly but found no debris.
Topped up fresh water system (maybe added a cup).
Back flushed all segmensts of seawater system with marina hose (including all three heat exchangers).
Problem persists. Today plan to:
Tighten alternator belt (which I believe drives the fresh water pump)
Find a way to examine the seawater intake outside the through hull (a kind of sharky marina)
Find the fresh water purge (forward on the exhaust manifold?)
Call American Diesel (love those guys!)
If none of that works plan to replace thermostat and remove and hand de-scale the primary heat exchanger.
Anybody have any other ideas?
Hi, thanks for your interest...
To backflush I disconnected hoses at multiple points and forced fresh water through the system in the direction against normal flow. Then checked the input end of the heat exchangers for obstruction. Today I also rodded out the main heat exchanger (or as much as i could reach while leaving it in place and examined the seawater intake with an underwater camera (nothing visible from outside the small grate over the intake). Ran 15 minutes at idle and watched Temperature gauge (is it the real T?) climb to 215 F.... Then I turned up the throttle and watched it apparently fall back to 195 F (still hot but acceptable).....
Tomorrow I will attach a thermocouple near the T sensor on the engine to verify or refute gauge at helm.
American Diesel (Brian) says it is probably the gauge itself. I am not so sure.
Jeff D.
