this engine does not start correctly unless I manually prime the carbs with spray bottle with gas.when it starts it runs good for the most part.the choke flaps are adjusted to close evenly and tightly to the carb body when the switch is ingaged.i took the thermo choke wires off and wired the dual stage silinoid directly per bulition info. both wires connected on the terminal bar.comprestion test read 140 on all 4 holes.even after it has run and up to temp and shut it off it soe times starts with a quick turn of the key but then there are times when it will not start.i have rebuilt the carbs and cleaned real good took out the welch plugs ran thin wire with 120 lbs of comp air in the small fuel passages.this hard start is driving me crazy.all new ele coil and power pack by cdi .I was thinking the fuel pump may be the culprit but it runs good at wide open and out off the hole with no sluggish sysmptoms.to be sure I changed it out with a good one and it is doing the same.someone told me the rings could be worn not getting the sucktion in the crankcase but with the reading of 140 that is real good for a 40 + year old engine.what else could be causeing this.
