cliveadams
" The trim motor on my 1980 Jo
" The trim motor on my 1980 Johnson 140 is not operating. When I try to trim UP, I hear the click of the relay but nothing happens. When I try to trim down I hear nothing, and nothing happens. The same thing happened the other day, and I had just about resigned myself to taking the powerhead off and removing the trim motor, when after a little banging with a rubber mallet on the trim motor, it started operating again. I took the boat around the lake - no problems at all. This time though, the banging trick didn't work.
The batteries and relay are not the problem - both deep cycle batteries are new and well over 12 volts, and the connections are fine - the same voltage as the battery is maintained through to the last connection before the wire goes into the motor. I have checked the amperage when trimming up and it's over 70, so it's drawing much more than it should.
Any hints before I remove the trim motor? It looks impossible to do this without removing the power head because one bolt is completely hidden next to the bracket - any tricks to minimize the effort?
Any ideas why the banging seemed to make it work the first time? "
