Hi setanta, your engine is different. Remove the coolant drain petcock on port side of engine and install a tee. Connect feed hose (to heater) to one side of tee and install removed petcock to other leg of tee. Heater return hose connects to portside of exhaust manifold forward where there should be a plug now. As to fuel on water you will see some particularly when the engine is cold. You might check injection pump timing but diesel is better (cleaner ) than heating oil. Coolant temp. Should be at least 185 f.charlie w.
Charlie, thanks for the response. I have all the original paperwork for the engines when they were installed in my Grand Banks. Engine plate reads 2714E and the ci. is 380. I didn't write it down but the plate has the build # etc. on it. I already have the block heaters, they were purchased by the previous owner. I just wanted to confirm with someone that all I do is punch out one of the freeze plugs and insert the tapered rubber plug on the heater. Is there any particular plug to punch or would the easiest one to access do?Hi timeless 42, i don't think you'll find one to fit. A magnetic 200 watt heater mounted center of block below ex/int manifold works well. Local parts store should have them.
Also if your engine is 1971, 120hp it should be a 2703e dorset 363 cubic inch.
Charlie w
