I'm a prospective buyer of a GB with twin 120 hp Ford Lehman 2714E diesels, 1974 vintage, about 3,000 hours. Baffled by the mechanics' oil pressure readings and eager for insights. New 30-wt oil in both engines (replaced 10-40). In neutral, at idle, cold start to 1500 rpms shows 25 psi. Revving up to 2000 rpms the oil pressure drops to 20 psi and stays. Readings are from independent gauges directly on the engine blocks. Temp shows 150 degrees. They stay at 20 psi until engine rpms are brought down to idle at 750 rpms. Same story for both engines. Mechanics say oil pressure should be 30 up to 40 psi. What could cause that? Engines sound ok; exhaust is pretty clear; oil analysis is pending.
