Marine 350 to chevy 350 swap motors
Redimport95
I have a 1985 baja force 200 with a marine 350 in it which recently siezed up. Everything else on the motor is fine...exhaust manafold, plugs, alternator, electrical ect..which I know are marine grade parts. I just recently purchased a 1986 small block 350 which came out of a blazer. If I switch over the cams to the 350 I purchased and change the gaskets and drop the motor in will i have a problem and will it be sufficant enough. Im generally not the type of person to beat the hell out of the motor. Its more of a money issue. Thanks...need imput!
Well, I've seen it done and it has generally worked, but I'm always a little skittish about that kind of R&R. You can shop around and get a Jasper rebuilt 350 marine short block for about $2600 +/- (with exchange) with a full year guarantee or better. And dropping in a 1986 350 for a 1985 350 sounds a bit penny wise and pound foolish in my book.
If you do decide to do it, be sure to change out the freeze plugs to brass or bronze - the OEM freeze plugs will rust out using raw water all the time. If you do not already have one, consider converting to a closed-loop cooling system if you are operating in salt water or brackish water. Even if you are operating in fresh water it's a good idea because your block and heads are getting the benefit of a coolant with antifreeze. That requires two water pumps and a water-to-coolant heat exchanger. You need one pump to pull the raw water up through your outdrive, through the heat exchanger and out the manifolds, and one to circulate coolant through the block and heads from the heat exchanger. Depending on how your current engine was set up, you may have both pumps already, and all that you need is the heat exchanger and hoses to re-rout the water and coolant flows. About every maire engine shop I have ever visited has several used heat exchangers laying around.
ALSO - change out the oil pan on the replacement engine to an aluminum one. The OEM pans have a very bad habit of rusting out in a marine environment. If your current engine has the canister type fuel filter, replace the can with aluminum or stainless. Often times a Ford can is a direct replacement (don't even ask why I know this!)
Inspect your manifolds and risers very carefully. If you are going to replace them any time soon, now is the time to do it. It is a lot easier to change then when the engine is out of the boat.
compression test the motor before doing all that work and check oil pressure at cranking
I'd probably cut a filter too
cam swap not always necessary, but who knows what cam may have been swapped into a 86 Blazer, so yes, best to do that.
Get new lifters. or, for the price of new lifters, you can probably get a cam and lifters kit for marine from Jegs or Summitt.
get brass core plugs to replace the tin ones or they will rust and leak
You can use a nice composite head gasket with stainless fire rings like FelPro etc.
You will want the proper head gaskets if it is raw water cooled... I'd be leary about a 25+ yr old auto engine taking on a second career in a boat... unless you want to rebuild it first.
You can purchase a marine 350 for much less than Jasper with a 2 year warranty from the guys in Maine. More like 1300.00
Ayuh,.... Would that be the Machine Shop that blanketed craigslist a few months ago,..??
Got a link to their site,..?? do they have a site,..??
I had a motor deal fall apart here locally, 'n am now thinkin',... just go Buy 1....
I wouldn't worry about it I put a 96 350 out of a truck in my boat swapped a few misc parts from the old engine then installed a pool heat exchanger on it and that only cost a 150 bucks for the exchanger and I have ran it a lot in the past 4 seasons and it works great the only thing I have done is change the oil every year
