Hi, Guyies.For the last 2 seasons I have been running my 1970 60 hp with no nutrual switch do to the switch being bad.After hearing some stories of bad things happening do to not haveing this switch hooked up .I went and changed the switch last week after adjusting the little plunger to the timer base cam. And it was still allowing me to crank the motor over when in gear.With the throttle linkage disconected and manually advanceing the motors throttle lever the switch worked fine.So is the problem in my controll box.My manual states that there is a hi rev switch in the controll box for the warm up lever.Is this switch on the same circut as the safty switch on the motor.If the warm up lever hi rev switch is adjusted out of wack could it be afecting the nutrual forward and reverse lever?
