Hi guyies, I would like to get some feedback on what octain I should be useing on my 1970 60 hp johnson.My book says to run atleast a 87 octain or higher but that was 40 years ago. With todays gas being junk should I run the 89 or stick with the 87 50-1 and add sea foam in each tank? I have glm after market pistons that I put in when I rebuilt this motor.These pistons are a lower comprestion ratio to run better with the new gas of today.Butt I have seen this qustion asked and everyone says something different.What is safely recommended.Allso I found out I was running the incorrect spark plug in the motor.I had champion l77jc4. When I went to buy new ones the guy said I should be running the ql77jc4.He explained to me it was a hotter plug.I gapped them a little over 30 as I plan to do a lot of trolling this spring.Can I get some feedback on all this Thank you Tony
