piston rings. 60 hp
48tony
hi,I have a set of piston & rings to install. The piston has 2 ring groves on it.The 2 rings i have are a bit different from one another one is flat the other has a bevel. In what order do I install the rings.And what direction should the bevel go. thanks tony
It is impossible to make a mistake on this.-----------------------------Examine the ring grooves CAREFULLY-----------use a magnifying glass if you must.
racer 1 your right it is a no brainer.after a good look i had a brain fart all good thanks. stay tuned for my next qustion.I would say dumb qustion but no qus is a dumb one exept my last one..
