Silverton 31
Began by having initial stalling by both engines. Discovered gasoline lost its fire power. Removed the entire contents of the 200-gallon fuel tank and replaced with fresh fuel. Replaced all the electronic parts distributors, ignition coils, external resistors, Chrysler ECMs of both Chrysler Marine 318's. Replaced all fuel lines copper and hose as well as the fuel/water separators and inline filters. Replaced fuel pumps (new) Had professional carburetor rebuilt both Edelbrock. Added the required Startron additive. Replaced all 16 spark plugs, and wires. I discovered a NEW defective coil (incorrect ohms) and one wire set had 3 bad wires which were replaced. After 3 boating seasons wasted, I now have the Starboard engine properly operating. Port engine will idle normal I can leave the slip and get above idle, then after 4 miles it will begin to lose rpms, tachometer jumps (indication stalling will occur) then stalls. Will fire back up but from that point will continue to stall. My son ordered a new Edelbrock carburetor. Installed and no improvement. OUT OF SOLUTIONS!
