scottcreeve
I have a 2001 Nissan 50d two stroke. When I fully tilt the motor up the tilt motor will not engage to lower the motor. The same happens when I fully lower the motor. If I do not fully tilt the motor up or down it works fine. I have checked the relays and they are fine. I have also replaced the tilt motor. This happens whether I use the tilt switch on the throttle or the switch on the motor itself. Since the engine starts no problem it cannot be the wiring of the battery to the outboard. The only thing I can think of is the wires from the two switches to the relays. I am not sure if they are independently wired or if they are connected together and then one common wire runs to the relays. Any suggestions to why this happens would be appreciated.
