pt-130 CMC tilt trim lift 7050 actuator motor problem
rob brew
i have a pt-130 CMC 7050 actuator motor that i burned out the part that holds the brushes on to the armeture. the rest of the motor checks out fine. i just need the brush holder assy. i can't seem to find any one that will sell the parts. CMC will rebuild it but i only want the part. do you have any sugestions
CMC probably does not make their own motors, but rather purchases them from a spe******t manufacturer like API. If you can determine the manufacturer, then you can likely find the parts or the replacement motor. I've done this in the past with a Honda tilt/trim motor and got a perfect replacement from API at one third the price Honda wanted to charge. It may take a good bit of online research, but the savings and availability may be well worth it.
ok thank you, i will look forthe manufacturer to night. i know that i can get a new motor, just hate to when all i need is this one piece.
Rob, the motor just went out in mine. how did you go about taking it apart all those bolts are a little intimidating. i have been trying to find an internal diagram but have not had any luck. thanks for any help.
thanks, it was a hope, not much more. i appreciate thy reply. i got the motor out, seems i need the same thing as he did. not having any luck, going to re-machine the top cap to hold available brush holders and brushes.
I have a cmc pt-35 and it will go down slow and it will go up really really slow can anyone tell me whats wrong with it done changed hydraulic fluid in it this morning and the wires are perfectly fine
