Michaeld5503
Hi all, We have a 1980 80 hp motor with a odd drive connector for the raw water pump. 2 metal plates with a plastic plate in between. Old style Lovejoy? Anyway, we are stuck in Mobile Bay on way to Tampa and looking for help. The pump bracket cracked, got a replacement installed it. Now when motor is running, pump wobbles I tried making a new center piece for the drive connection out of starboard with slightly larger holes but still get the wobble. The pump side plate ( with 2 pins on it) is worn around the keyway, probably case of wobble. High pressure pump side ( splined with 2 pins ) is in good shape. Anyone know where to get a replacement? Upgrade?
As I said, we are stranded motorless in Mobile Bay and want to get to Tampa before New Years. Any suggestion?
ODAY
ODAY
