Good day,
My manifold were shot and did not have the money to get new ones. Looked on craigslist found these ones. They looked in good shape but have a few too many ports.
from the heat exchanger,
i have two output one is coming out of the heat exchanger itself and the other one is from oil cooler. from there they are split in two. the one from the heat exhanger goes to the front of the manifolds.
The other one comes out of the oil cooler and is mounted on the 20 degree elbow.
As you can see in this picture there is an output that we had in the back of the manifold that we blocked to keep with the same setup.
The manifold heated bad.
We removed the back plate and noticed that the plate was completely block
( i believe its because of the different setup) now its free flowing nicely.
With everything explained, I have a few questions...
(1) Would you please identify the manifold Part # shown in the attachments.
(2) Does this manifold require distribution tubes and or will they accept same ?
(3) What is the part # for the rear gasket and should it be an open or closed ?
Thanks for your help.
