Thanks, will check .Hi,
Is yours an A model or a D model?
I have good info for the A model fuse locations but I don't have anything but a vague description for the D model.
The three A model fuse "boxes" are lined up just behind the starter on the stbd. (right) side.
The one to the rear is the 10 amp ignition-trim/tilt fuse.
The D model is different. I believe that there is an enclosure with a removable cover on the port (left hand) side of the engine that houses all of the fuses. The 10 amp #5 fuse is the ignition/ trim fuse.
Hopefully this helps you.
Good luck.
