Volvo Penta Marine AQ130 differences
"I am curious to find out if m
"I am curious to find out if my engine is a aq130 a,b,c or d. Is there any EASY way to tell what it is? I think that it is the second motor in the boat and it has b20 stamped on it. It has a 270 outdrive, two solex carbs if that helps. It runs great at 90 psi....anyone?!?!?!?"
"can a aq130 a,b,c,and d all b
"can a aq130 a,b,c,and d all bolt up to a 270 outdrive?"
"I was just reviewing past pos
"I was just reviewing past postings and found one from June 25 2006 where el showed where the brass nameplate is. Found it, aq130c/270. Does anyone know why this runs great at 90 psi when it should have to be at 170-200 psi?!?!?! Thanks"
"Aaron, 170-200 psi would be a
"Aaron, 170-200 psi would be acceptable for 'New' motors. I've just been looking for info also on the AQ130D (mine has a case of water in the oil! Still troubleshooting) and I've discovered some news to me about it. It seems that the "D" /280 was made mostly for the U.S. market, and according to the SELOC '68-91 Stern Drives book, had a CR of 9.5:1 (thus the high numbers for PSI you quoted)[the volvo flyer says 9.0:1]. I'll guess the reason is because 102 Octane Rating gas was easy available here in those days ('75-77). If yours is running nicely at 90 - why complain. An "E" model ('73-74) was produced for the U.S. market and Europa racers (auto) with CR 10.4:1 (and with intake valves 11.6% bigger than 'D'), but who wants to be mixing fuels to get the higher Octane in order to keep from 'pinging' & engine damage? Most autos these days are running around CR 8.5:1 (the "B" model had 8.4:1 per SELOC).
Good luck with yours."
Does anyone know where I can f
Does anyone know where I can find a piston and rings for a AQ130C
"I have a 1973 130c/270T, it r
"I have a 1973 130c/270T, it runs great in the drive way but will only idle when in water. The rear carb fluds out. I am considering converting to a single 2 brl. Any ideas or comments would be appreciated."
I have a 1976 130d and need an
I have a 1976 130d and need an exhaust manifold. Does anyone know where I could find one?
"I have a AQ130A with a 250D l
"I have a AQ130A with a 250D leg, what i am looking for is information on the Drive?leg.
I am running a 14 x 19L ali prop and not sure that this is the original.
What i need to know is the drive ratio and original prop size, so if anybody can help it would be appreciated.
If anybody requires the manual for AQ130 A,B,C & D send me an e-mail i will be happy to forward it."
"Hello I have a B20 Engine Vol
"Hello I have a B20 Engine Volvo penta but Im try to buy a water pump, boy I dont know if is the same AQ130 that B20 can you help me? I found a part number for the pump but I not sure if this is the pump for the engine. the numver is 9900-0001 from JABSCO this pump is for AQ95-140 / BB30 /MD5 engines. Regards Carlos"
"Carlos,
First, try to find
"Carlos,
First, try to find the brass plate riveted to the engine block that has engraved the model of your engine. Check this link to find out where to look for it:
http://www.marineengine.com/discus/messages/12487/22475.shtml
The important thing is to verify that you have an AQ130 engine (a B20, 130 HP Volvo Penta). If this is the case, either of the three pumps at the top right of this link will work:
http://www.depcopump.com/catalog107/102.pdf
or if you prefer to get it from Volvo Penta:
http://www.volvopentastore.com/SEA_WATER_PUMP_825916/dm/Remove/dm/store_id.366-- session_id.279302186--cart_id.270723103--category_id.332342--viewcart.long--view _id.317258--qty_320402.0
or from Doug Russell:
http://www.dougrussell.com/partscatalog/volvo_omc/index.cfm?fuseaction=comp&grou p=3408&GroupList=3404,3405,3406,3407,3408,3403,3409,3411,3410,3412,3413,3414,341 5,3416,3417,3418,3419,3422,3420,3421,3423,3424,3425,3426,3427,3428,3429
Alternatively, you can check e-bay, as those pumps come every now and then for sale. Here is one:
http://cgi.ebay.com/ebaymotors/VOLVO-PENTA-B20-AQ130-ENGINE-SEAWATER-PUMP-COPPER -TUBES_W0QQcmdZViewItemQQcategoryZ50442QQihZ015QQitemZ250211638130QQrdZ1QQsspage nameZWDVW
Please let me know if you have any further questions."
I have a Volvo Penta AQ120 B w
I have a Volvo Penta AQ120 B with a Solex carburetor # 44PHN .Have been searching for a float for that carb. anyone out there might have or know where I can get one ?
"I rebuilt my AQ130D myself an
"I rebuilt my AQ130D myself and it kept blowing out the felt seal on the timing chain cover around the crankshaft end. I was told it was because I honed out the cylinders instead of boring them. I had it professonly rebuilt and 1 year later the seal is leaking again. Does anyone know of a fix or mod for this? Thanks, Mike"
I have a Ranger 18ft with the
I have a Ranger 18ft with the volvo 130 I am thinking of buying...
Has a little water in oil... Owner says that there was or possibly still is a problem with the heat exchanger leaking water in the oil.. does anyone know anything about this?
Wondering if the water could be getting in another way?
Wants $1000 for the works
THANKS!
Good day, new here and I didn't know exactly where this would be classified. I have an aq170 I believe race engine. I found in barn in crate. Is new never installed. Has triple dcoe carbs on it. Looked in cylinders all looked great and new so fired it up runs great. Anyone have an interest in these.have pics . Any information would be greatly appreciated thanks
