yamaha2strokeoutboard
![001.jpg 001.jpg](https://www.marineengine.com/boat-forum/data/attachments/14/14572-4128d33c4e2264567697c44f2d05e280.jpg)
https://www.yama2strokeoutboard.com/
Engine Features: 2-cylinder. 2-beat
Displacement (cc): 165
Compression ratio: 7.0
Power (hp): 8
Bore x Stroke (mm): 50 x 42
Range max engine speed: 4000-5500 rpm
Ignition System: CDI
Purge: Intersection
Power System: 1 carburetor
Fuel tank (L): 12
Max. fuel consumption (l / h): 4.5
Lubrication System: Premixing
The proportion of the fuel-oil mixture: 50: 1
Alternator: 6A, 80 W
Starter: Manual
Control System: Tiller
Gear Shift: FNR
Gear Ratio: 2.08 (27/13)
Exhaust System: Through the hub of the propeller (JET system (Reactive))
Propeller drive gearing: spline connection
Transom engine height: S 436 mm (17.2 inches)
Dry weight with propeller: 27.0 kg
Trimming and folding: manual
Cable lanyard to stop the engine - yes
Motor deviation when moving in shallow water - yes
Rectifier-regulator: rectifier with regulator
Starter lock during reverse - yes
