yamaha FL200
harbor720
Planning on changing the oil on Yamaha 2017 FL200 using Evindure/Johnson 25-40 FWC oil and Fram ultra 3614 filter anyone see any problem??
Why use non-specified oil? It does not have to be Yamalube. Just get the correct grade.
I have no knowledge of the filter you mention. If it is form, fit and function the equivalent of the Yamaha branded (made by Denso) filter then I would have no problem using it.
In the future it will help if you post the full model of your motor. Yamaha makes several I4 and V6 four stroke 200 HP motors. An LF200 model is not offered here in the USA. You must not be in the US.
