Yanmar 4JH5E sea water pump question
Emtktr
I’m rebuilding the sea water pump. All drawings are informative however I’m not able to figure out the orientation of the V Ring X02230015. It is part number 12 on the attached image. Any help would be appreciated...thanks 868F37C5-0BCC-4946-8047-4C19E830A93B.jpg
V-rings are fitted on the spigot and inserted into the L-joint. Before the spigot with V-ring is inserted in the socket, the original KeraMat lubricant must be applied in the vitrified clay pipe socket and on the V-ring. thank you.
