15 hp only runs on Choke
Avsh
Hello,
Mercury 15hp 2 stroke. engine only runs on choke position, and when I press the primer fuel squirts from the hole. What could be the reason for this? Thank you
I would say that you have possibly two problems,plugged main jet and a bad float or inlet needle.Carb needs to come off for inspection and repair.
What test can be performed to rule out a leaking seal at the entrance? If I don't have an extra gasket at the moment
I cleaned the carburetor still not running well
