2007 bf 115 on my pontoon. Engine will start up and idle fine, can get it up on plane and run for a bit and runs good. Then all of a sudden the engine will start to spudder and stall and the more throttle you give it the worse it runs untill eventually it will barely idle and run. In order to try and fix this i have:
-cleaned gas tank and added fresh gas
-cleaned or replaced all fuel filters
-cleaned vst and replaced hp filter section with fresh o rings and holder
-new ignition coils
-new spark plugs
-new fuel line from tank to motor
-Removed and clean fuel injectors
What else could be going on? The motor runs decent for a period of time then just seems like it is starving for fuel but at the same time wont take fuel. I also have a low pressure fuel pump coming in the mail and if that dosent work then i am all out of ideas. Thanks for any and all help!
-new ignition coils
-new spark plugs
