70 hp mariner problem
serial # is ?-----Have you replaced the impeller ?-----Testing in a bucket with water 6" above the impeller ?---On muffs ?----With boat floating in the water ?
Yes we were running the boat in the water and the alarm went off on it for overheating and the water coming out of the pee tube was hot.
Have you replaced the impeller , yes or no?----Outboards need a new impeller about every 5 years.----Why mention the compression with the alarm.
Serial # of this motor ?----Find the cause of overheat.----Poppit valve inspected ( if it has one ) for damage / blockage.
