sandkicker
Outstanding Contributor
Engine S/N 0F229xxx
Friend's boat.... been fixing the obvious bad stuff for him as "his plate is full" and just got to the elbows...Engine has no symptoms of elbow problems,just looking at possible PM.
Apparently elbows are NLA and also apparently there are 2 versions listed , a 816900A5 and an
A7. From what I see, the A7 is spec'd as stainless but can't find out if the A5 was as well (should be but???) . If the boat wasn't a hours drive away, I'd just take a file to the elbow and check the material... Two questions.... Any way to tell if A5 or A7 from the S/N? And most importantly, these look like the original elbows... If stainless, what is the life expectancy??? Engine has heat exchanger and is a full system.
