perryrlund
I have a 9.9 Honda that is 7 years old. Never a problem with it. Had it out a couple times this spring. Yesterday took it out and it ran for about 30 seconds and shut down. Restarted and same thing. Looked and no water discharge from the water pump hose. At home took side plate off. You have two hoses that go through the side plate for discharge. You have the black rubber one which is the main discharge from the water pump. This is where the water pees out when running. This hose was clear. The other one is a clear plastic one that come off the upper part of the motor. This one was plugged with some gunk. You could not blow through it. Took this hose off and cleaned it out. Problem fixed, I assumed. Took the boat down to the lake and started it and it was peeing out water as it should. Ran it for about 3 minutes and started to sputter and stopped peeing out water again. Looked at both of the hoses and no problems there. This, I thought, is an impeller/water pump problem. Took the intake screen off and as clean is the day it was new. Definitely thinking it's now a bad impeller in the water pump. Took the lower unit off and the impeller is in perfect condition. Will put a new impeller kit in as long as I have it apart.
The only two other explanations would be a thermostat issue or a blockage somewhere in the circulation in the cooling system itself. The motor is ver clean and no debris at all when I took off the intake screen and no debris in the impeller housing, it's as clean as the day it was new.
Any thoughts on this? I will replace the thermostat but prior to doing that I was wondering if any one else has any thoughts. I'm assuming if the thermostat is not working properly and the engine begins to overheat the engine shuts itself down.
Last question, you have the rubber black hose that discharges the water from the cooling system out the side panel. This is the peeing stream. Then right next to it you have the clear plastic line that attaches to a nipple on the top side of the motor. What is the purpose of the clear plastic line that comes out the nipple? Is it some type of water discharge line from the top of the motor or is it some type of line that would flush any water from the carb? Being that it is clear, I'm thinking it might be gas related and not water related.
Any help from the Honda experts would be appreciated.
