"Hi all,
apologies if this
"Hi all,
apologies if this is one of those repeat questions that gets asked all the time... but what kind of compression readings should I expect from a 15hp 1993 Merc 2-stroke? My first tests give readings of about 77 psi for the #1 cyl and 71 for #2. Seems awfully low, or is this normal for an engine of this power range?
The caveat is that I'm not 100% sure about my readings since my meter is a cheapo model that seemed to have some trouble getting a tight fit. But knowing what I should be seeing would make troubleshooting easier, whether it's the engine or the meter.
The engine is recently acquired with an unknown service history, so I haven't had any major diagnostics or shop work done yet. Seems to run fairly well, though, on the first quick test drives."
apologies if this
"Hi all,
