Nissan NS18C2 parts
Rjybilcom
Can someone give me the part number for the clutch dog gear, pin, and spring for this NS18C2, Serial number 350A-1 62782? I have the exploded diagram but no part numbers.
Thanks. Found all three on eBay.
This is the first weekend that I've been to the campground since getting the parts. So I dropper the lower unit and removed the prop, then removed the two bolts for the propeller housing. It fell apart on me. After I pulled the propeller shaft, I don't see any damage to the clutch dog or reverse gear. I found a used prop housing on eBay for 19.99 and should have it by next weekend.
Hi, would you happen to know how many bolts there are to drop the lower unit? I have this same motor and need to change my water pump impeller, but after removing the 4 lower unit bolts and the pin for the shift linkage it wont budge at all. Wondering if there is a hidden bolt somewhere or if my driveshaft splines are twisted.
