aquaholictom
I have a 1978 - 150 HP V-6 -Mercury Outboard - Stopped running. When I checked spark found out I only had spark on the right bank, nothing on the left bank. Checked each spark plug for spark and none available??
Which wire is the trigger wire?Re: Only 3 cylinders are getting spark
I believe you model did NOT have an idle stablizer module, so a bad switchbox would be the leading contender.
You have 2 switchboxes, one for each cylinder bank...
I believe the advice you would get from most guys who work on these would be to replace both switchboxes, one often follows the other when they go - but at a little over 200 bucks a piece (list price), it is a little pricey...
Should have added - to confirm it's a bad switch box, simply swap the wires around (from the trigger and stator, not the spark plugs) - if the bad bank starts firing and the good bank goes dead, then it's definately the switchbox...
I also changed the stator and have the same issue. Could the trigger cause this?I have Mercury ProMax 150 EFI that is dead on one bank. I have changed the switch box and still same thing.
I changed the $700 stator and have the same issue
