Engine 2007 Volvo Engine 5.7Gi EFI
Engine Stalls at Idle.
I Have cleaned the flame arrester
Fitted a new OEM IAC Valve
Fitted the e-clip to the fuel pressure regulator
Checked fuel pressure low pressure pump 18psi (manual says it should be 8psi ?)OK at all revs
Checked high pressure fuel pump 52psi OK at al revs
Fitted new fuel filter
New spark plugs
New leads,dizzy & rotor
No fault codes on Rinda Tool
If I adjut the RPM to 850rpm it runs ok and doesn't cut out
any help appreciated
New spark plugs
