P
Patrick Isaac
Guest
"If anyone has any idea on thi
"If anyone has any idea on this please help me. I had a 5.0gi Volvo engine in my boat, it was a used boat with about 80 hours on it. I put about 80 hours on it in one season and had no problems with it. before I winterized it, it froze, but I found no visible damage from that. I put the boat in the water ran it for about 6 hours with no problem. Then I "tuliped" a valve, number 3 cylinder. I replaced the engine with a 5.7 liter Jasper. I used the intake and distributor from the old 5.0 engine, but I replaced most of the other parts, exhust and so on.. Ran the new engine for about 3 hours and tuliped the same exact valve.
Had a professional work on it, replaced the head and now I get back firing and the engine cuts out when it is moving. When idleing it is okay, but when you start moving it cuts out and back fires. Does the same thing at higher rpms also.
Any idea what could have cause the valves to tulip on two different motors? what is causeing the cut out and back firing? Intake manifold? Distributor? Computer? I have no clue. Thanks,"
