papyson
Outstanding Contributor
i have a 60 hp 4cycle merc...new motor and a old boat with a built in 18 gallon aluminum tank...it has a canister type inline water filter....today it started cutting out ....99% sure fuel problem...remove fuel filter...it appeared and smelled like it had very little gas in it...when i dumped it there was very little gas on the water..looked like water at first and then was a white colored liguid and then it turned tan in color...put the same filter back on and motor still would slowly slow down and would die if i left throttle open....finally found a speed where motor would keep running....this was at about 2200 rpm..i was alone and could not reach bulp to pump it but the bulb had about the right amount of pressure when i got back there to feel it..my question is this: are these fuel filters what i call full flow filters?...by that i mean if the filter is junked up does the gas bypass them and just go unfiltered to the engine?....i have not checked the under the cowl filter...the boat is still in the water...
