astroglass_81
"1980 Mercury 90 HP Outboard
Model: 1090620 90ELPTO
Serial: 7179095
Soaked carbs and cleaned up well, installed new gaskets, needles & seats. Checked float levels per Mercury Service Manual. Installed new plugs, & performed complete timing and syncronization procedure. Installed ear muffs, started engine & adjusted carbs. Motor ran smooth. Took to ramp to test run. Started engine, running smooth, then gas started pouring out of bottom of front cowling. Shut off engine, removed cowling & discovered center carb gushing gas out vent. Tapped on carb to try jarring float to no avail. Manual states with float bowl cover inverted, the secondary lever is supposed to be 13/32" or 10mm. From where? top of rim for gasket, gasket suface without gasket or gasket surface with gasket? Thanks in advance. and all info appreciated."
Serial: 7179095
