Post the compression test values here.-----And were the carburetor bowls checked ?----They often warp with time.-----List the parts you have replaced as that may help in diagnosis.
95ish psi all around. Replaced plugs, wires, rebuilt carbs twice, replaced reed valves (CCMS) and gaskets, replaced complete fuel line w/correct liner inside, replaced fuel nozzle on front, replaced all o-rings on the 2 fuel rails, replaced vapor sep dasket, replaced power pack with CDI unit, replaced vacuum hoses, replaced optical sensor ...all I can think of at the moment.95ish psi all around. Replaced plugs, wires, rebuilt carbs twice, replaced reed valves (CCMS) and gaskets, replaced complete fuel line w/correct liner inside, replaced fuel nozzle on front, replaced all o-rings on the 2 fuel rails, replaced vapor sep dasket, replaced power pack with CDI unit, replaced vacuum hoses, replaced optical sensor ...all I can think of at the moment.
Rebuilt the fuel pump and carb bowls all look virtually new and not warped.95ish psi all around. Replaced plugs, wires, rebuilt carbs twice, replaced reed valves (CCMS) and gaskets, replaced complete fuel line w/correct liner inside, replaced fuel nozzle on front, replaced all o-rings on the 2 fuel rails, replaced vapor sep dasket, replaced power pack with CDI unit, replaced vacuum hoses, replaced optical sensor ...all I can think of at the moment.
My buddy reminded me, they are new carb bowls.95ish psi all around. Replaced plugs, wires, rebuilt carbs twice, replaced reed valves (CCMS) and gaskets, replaced complete fuel line w/correct liner inside, replaced fuel nozzle on front, replaced all o-rings on the 2 fuel rails, replaced vapor sep dasket, replaced power pack with CDI unit, replaced vacuum hoses, replaced optical sensor ...all I can think of at the moment.
Yes, as a matter of fact my buddy is taking all back apart tomorrow and use a wire brush to clean things out, not just a spray cleaner. He's done this before but maybe not good enough, who knowsHigh speed jets swapped over to the new bowls ?
